Frustrating AMD socket fans.....
Postby CivilDissent » Mon Feb 05, 2007 9:55 am
I have used AMD processors for a while now but they have always had the stock fan. I finally ordered a Zalman for my new setup and realized, after trying to install it, that the cotton picking mounting bracket on AMD CPUs are sideways. Now, I cannot mount my Zalman in the direction that I wanted to, straight towards my 140mm case exhaust fan that is only 30mm away! It would have been a perfect airflow!
So, does anyone know somewhere that sells "mounting bracket converter" that will turn the direction of the fan 90 degrees so that I can get my fan going towards the exhaust fan again. :?
"A mouth does not have to be open for words to be said or be spoken."
1836
The Year the Greatest Nation on Earth was
Founded!
"Honor the Texas Flag.
I pledge allegiance to thee,
Texas, one and indivisible."
CivilDissent
Postby ajrox » Fri Feb 09, 2007 3:10 pm
which one is it?
i had an arctic freezer that was like that. so i took off the stock fan, got 2 90mm fans as they were just a little bigger. then monted them as i needed them to be. 1 as an intake to push air through and the other as an exhaust to pull air out. i just sandwiched the heatsink in between the fans and used long bolts from the hardware store to mount them with.
AJ
EVGA 790i tri SLI
intel core2 quad 9550
6gb G.SKILL DDR3 16000
3X EVGA 8800gts video cards
water cooled fo sho
the rest when i get paid
ajrox
