It is currently Mon Feb 18, 2019 6:37 am
PostPosted: Wed Oct 25, 2006 3:57 pm
What are the pros and cons and which is better?
PostPosted: Mon Nov 06, 2006 1:51 pm
What do you mean exactly when you say "side"?
The Gift of Healing
Conscious Energy Meditation
 Post subject: Here
PostPosted: Mon Nov 06, 2006 3:45 pm
On top of the heatsink or mounted on the side of the heatsink.
PostPosted: Mon Nov 06, 2006 4:06 pm
Typically the "side" mounted heatsinks are taller and more of an extremist solution. They tend to be heavier and put more stress on the motherboard.
The "top" mounted are your more typical heatsink and can deliver very good performance without all that extra weight or lost space.
I'd say stick with the traditional style and if you need more go ahead and get water cooling.
RIAA vs The People
