It is currently Sat Oct 20, 2018 4:56 am
 Post subject: In need of 120 mm fans
PostPosted: Sat Aug 19, 2006 4:34 pm
BANNED!
Hey I am buying a new Heatsink/Fan for my CPU. The CPU is a AMD Athlon 3000+ venice and I am gonna for a good overclock. I am going for this HS/Fan:
http://jab-tech.com/Scythe-Ninja-Plus-6 ... -3281.html
Anyways. I also have read about some overclocking and noticed that I should probably get some better case cooling on this Aspire Navigator Case. It has 2 puny 80mm fans one top and one back. Of course it has a PSU fan but I still would like to 120mmfans. I want one for the back and one for the front to increae airflow. Anyways, anyone got anyideas of what are some good fans or tricks to decrease temps on both the cpu and overall system.
PostPosted: Sat Aug 19, 2006 6:07 pm
I was looking at your HS/F choice and came across this review:
http://www.xbitlabs.com/articles/cooler ... 120_8.html
Thought you might be interested in the results. The Tuniq T-120 is nice but its more expensive and larger then the cooler your looking at. Found it for sale here:
http://www.frozencpu.com/cpu-tnq-01
7 degrees is a BIG difference on air. :wink:
Asus F2A85-V Pro
AMD A10-5800K APU @ 4.5GHz
8GB G. Skill 1866
550w PSU
Hyper 212 Evo
PostPosted: Sat Aug 19, 2006 9:53 pm
BANNED!
That T 120 is good but might not fit in my case. Anyways any ideas on the case fans.
PostPosted: Sat Aug 19, 2006 10:32 pm
I dont think theres a real big difference between 120mm fans. Most should run about the same.
CFM is important.. Heres a 78CFM "shiny" one.
http://www.newegg.com/Product/Product.a ... 6811999128 but its loud (as far as 120mm ones go..)
or just pick one that suits your style, noise ratio, and budget..
http://www.newegg.com/Product/ProductLi ... an&Ntk=all
:wink:
Asus F2A85-V Pro
8GB G. Skill 1866
550w PSU
Hyper 212 Evo
PostPosted: Sun Aug 20, 2006 7:52 am
BANNED!
Those look good but I was also wanting a fan that is silent and no led lighting.
PostPosted: Sun Aug 20, 2006 8:37 am
GeF, check out Nexus fans. I use them on all my builds because I've found they produce the least noise while still performing.
PostPosted: Sun Aug 20, 2006 9:59 am
BANNED!
That 120 fan looks nice but I am kind of iffy on the price. I don't want to spend more than $10 per fan unless the temps will be fenominal. Plus my room stays at about 87 F so.
PostPosted: Sun Aug 20, 2006 10:36 am
with those ambient temps it will be hard to get a fan to do the job for under that price and be quiet i would not recommend a 35cfm fan i would go with something with more air flow this fan meets your price but will not be quiet it is rated at 90 cfm 44.5 db not sure what the test methods they used to determine the sound level but you might get the sound down by using sound dampening technique like rubber washers or a silicone gasket like antec sells.
PostPosted: Sun Aug 20, 2006 11:10 am
BANNED!
It looks nice can you tell me where to find some good sound depletion techniques and where I can get rubber washers and such.
PostPosted: Sun Aug 20, 2006 1:18 pm
http://www.endpcnoise.com/cgi-bin/e/index.html
alot of that stuff can probably be bought at a hardware store for a lot less. same goes with rubber washers and such.
Asus F2A85-V Pro
8GB G. Skill 1866
550w PSU
Hyper 212 Evo
