It is currently Mon Oct 22, 2018 7:49 pm
 Post subject: temps
PostPosted: Thu Aug 17, 2006 6:51 am
witch program is better everest or mm5
i got both and there telling me two different temps for the mb and cpu
K8n-NEO2 platium,AwardBIOS v6.00PG,AMD Athlon(tm) 64 Processor 4000+ Socket 939,ati radeon 9800 xt 256 agp ,windows XP w/service pack 2,2 G`s ram ddr 3200,running dual monitors
PostPosted: Thu Aug 17, 2006 11:32 am
I'd trust MBM5 for temps.
RIAA vs The People
PostPosted: Thu Aug 17, 2006 1:22 pm
i forgot to mention that i also got the core cell that came with the mb and everytime i start it, the darn alarm is going off and shuts it down
i can reach in and feel the finns on the cpu heat sink and they feel cool to the touch
but the video card felt kinda to warm so
i just added a little mini fan to the video card to see if that helps
PostPosted: Thu Aug 17, 2006 5:00 pm
Deffiantly MBM.
PostPosted: Thu Aug 17, 2006 7:03 pm
If we are talking about the MSI K8N series? (that's the one in the siggy)
Forget motherboard monitor.
Download from MSI the latest edition of their own motherboard monitor program. On my board (K8N Neo4) it's known as "Core Center". It gives options, alarms...temp readings..and voltage readings. (basically it's designed to work with their own hardware)
S-
PostPosted: Thu Aug 17, 2006 9:03 pm
S-
that keeps shutting down the puter every time i start it the alarm goes off i just did a freash install im going to try it as soon as i get the mb cd in
 Post subject: Re: temps
PostPosted: Mon Sep 18, 2006 6:43 am
The two programs should be reading almost the same temps.
Some motherboards just give false temp readings .
Only way to tell for sure is to use a digital thermometer .
E Pluribus Unum
