It is currently Fri Aug 17, 2018 7:25 am
PostPosted: Sat Jun 03, 2006 10:52 am
guys,
simple question, but haven't installed a CPU since ages:
got myself a pentium d processor, with the stock intel hs/f which had a thermal pad on it.
put it on.
then, made a mistake: took it off again. obviously, this messed up the cooling.
do i now need to clean the CPU and hs/f and apply a new thermal pad, or can i use some thermal paste instead? am a bit unclear about this... thanks for any answers!
PostPosted: Sat Jun 03, 2006 5:53 pm
A pad is typically a one use item. Clean it all off and make sure you use 70% or better isopropyl alcohol. Then apply thermal paste.
RIAA vs The People
PostPosted: Wed Jun 28, 2006 10:06 pm
Thermal pads are designed to be simple and to work, but paste can do a better job and is usually better (when you get high quality paste like Artic silver 5 or Ceramique)
Shuttle SN45G, AMD AthlonXP 3000+, 2x512MB Crucial DDR333, 80GB WD HD, Sony DRU-720A DVRW, MSI Radeon 9800 Pro 128MB, Dell 24" widescreen LCD
