The Dom wrote:Not to familiar with that case, but if you can remove the side panel use a regular house fan and blow air into the case from the side against the processor. This should drop your temps a bit and is the cheapest solution if you got a fan you can use until you can afford a new computer.
Divingsoccerplayer wrote:I don't know if my processor is the culprit but a full load at 84C I think could be causing part of the problem....
