overheating videocard
Postby R for Republican » Thu May 11, 2006 10:59 am
Well my comp dosnt have a video cooler...i wanted to know what kind i should get..
my temps are around 75-80c when i play my games
i have a
Geforce 6600GT
and it makes a car horn sound when it starts to overheat..:D
SpranoRS101
Asus M3NHT
2x2GB Mushkin Blackline
Phenom II x4 3.4
R for Republican
Postby jimmy-j » Sat May 13, 2006 10:17 pm
Are you sure your 6600 GT card has passive heating? I have one of those cards and the cooler and fan are quite large. On second thought I think you may have one of those new cards that have heat-pipe coolers, If this is your issue then your case temp's are where you are haveing the problems and you need to increase the through-put of air by increasing your fan size or fitting additional fans as required
jimmy-j
