It is currently Sat Aug 18, 2018 11:53 pm
 Post subject: Oily PC?
PostPosted: Wed Apr 26, 2006 9:35 am
A friend asked me out-of-the-blue if I had some spare computer parts. When I asked why he told me that he heard that a computer can run completely submerged in oil, as long it's 32 degrees or cooler.
Personally, I think he's about to ruin one of my extra motherboards.
Has anyone else heard of this? If so, is it degrees Celcius or Ferienheit(SP)? Does it matter what kind of oil you use? What precautions should I take before attempting this (aside from having a fire extinguisher ready)?
Meow?
Mnyaa.
PostPosted: Wed Apr 26, 2006 2:59 pm
Here is what he probably read. http://www.tomshardware.com/2006/01/09/ ... _the_fans/
CPU = Intel 3.06ghz
MOTHERBOARD = MSI 875P NEO LSR
RAM = Corsair 1024mb PC2700 XMS
OS = Win XP Sp2
POWER SUPPLY = Antec true power 480w
VIDEO CARD = PNY GF 6600 256MB
CASE =Antec PLUSVIEW 1000AMG
DVD = Lite on 16x
CDRW = Lite on 52x-24x-52x
PostPosted: Wed Apr 26, 2006 5:04 pm
it might work for awhile but depending on the oil it will evenually destroy the board or the oil. some of the components are not oil resistant.
