Water cooling for BTX?
Postby dougsherwood1320 » Fri Apr 14, 2006 10:01 am
I have just completed a new media workstation that uses a BTX mobo and a dual core pentium D.
The HSF "thermal moduale" works fine but, is noisy.
Does anyone know of a water cooling solution for BTX?
8)
SOME THINGS MUST BE BELIEVED TO BE SEEN
MEMBER- MOTHERBOARDS.ORG FOLDING TEAM
>>>>>>>>>1,000,000 POINTS<<<<<<<<<
dougsherwood1320
Re: Water cooling for BTX?
Postby joshvee » Fri Apr 14, 2006 11:28 am
dougsherwood1320 wrote:I have just completed a new media workstation that uses a BTX mobo and a dual core pentium D.
8)
Any water cooling system should be adaptable to fit BTX. It's just a question of cutting the tubes to the correct length and finding an appropriate place to fit the water pump and radiator.
joshvee
Postby dougsherwood1320 » Fri Apr 14, 2006 6:10 pm
What about the way BTX mounts the water block? It is different than standard type HSF's. Maybe I could fabricate something? :?
How about a high performance HSF?
dougsherwood1320
Postby joshvee » Sat Apr 15, 2006 6:48 am
dougsherwood1320 wrote:What about the way BTX mounts the water block? It is different than standard type HSF's. Maybe I could fabricate something? :?
AHh ok u got me there. I thought BTX heatsinks mounted the same way normal heatsinks mount... just that the CPU was in a different position thats all.
joshvee
Postby Tulatin » Sat Apr 15, 2006 10:30 am
Naw josh, the BTX holes are basically like 100MM farther apart than before.
Doug, just e-mail DangerDen, and ask them to make you a custon top for one of their blocks, just give em the specs and it should be good :D
Tulatin
Postby joshvee » Sat Apr 15, 2006 9:28 pm
Tulatin wrote:Naw josh, the BTX holes are basically like 100MM farther apart than before.
Info assimilated and memorised. :mb_afro::
joshvee
Postby drkCrix » Sun Apr 30, 2006 12:10 pm
I know the TT 735 and 745 kits have BTX mounting brackets
drkCrix
