It is currently Sat Aug 18, 2018 12:44 am
 Post subject: Swifttech
PostPosted: Wed Mar 01, 2006 9:01 am
How do I remove the black pins holding the fan on the swifttech V heatsink?
PostPosted: Sat Mar 04, 2006 7:07 am
Look on the back side and you'll see a round ecpander pin in the center, push this in with a small object, this will raise up the outer protion where you can pull it out. With that pulled up, you should beable to remove the complete pin.
