AMD AThlon 1000 temp.
Postby HaloCorn » Fri Feb 03, 2006 11:10 pm
What is the idle tempurature supposed to be for a Athlon 1000 mhz?
GIGABYTE GA-M57SLi S4
AMD Athlon 64 X2 6000+
6 gigs o' Ocz reaper pc6400 (2x1gb 2x2gb)
2x Nvidia 8800GT 512MB Fact. OC'ed
3xWD 500Gb 16mb cache sata2
MX518
G15
IceMat Siberia Headset
650 W PSU
Gigabyte 3D Mars (case)
Acer AL2223W (monitor)
Windows Vista 64-Bit SP1
HaloCorn
Postby DAVE1 » Sat Feb 04, 2006 9:17 am
which model is it ?
here is a list of amd mad die temps not sure which model it is so here you go
http://www.motherboards.org/forums/viewtopic.php?t=5412
Join team 33258 today!!
DAVE1
Postby HaloCorn » Sat Feb 04, 2006 9:27 am
Thanks, I just thought 75º was a little hot but i guess not.
MX518
G15
650 W PSU
HaloCorn
Postby DAVE1 » Sat Feb 04, 2006 9:32 am
HaloCorn wrote:Thanks, I just thought 75º was a little hot but i guess not.
Its hot for todays cpu's... the older cpu's ran alot hotter especially AMD back then
DAVE1
Postby ~PJ~ » Sat Feb 04, 2006 9:51 am
Try a faster fan or check the ventilation to the case.
Peace for its people,
Love in our lives,
Delight in the good,
Forgiveness for past wrongs,
And from now on a new start.
~PJ~
Postby HaloCorn » Sat Feb 04, 2006 10:03 am
~PJ~ wrote:Try a faster fan or check the ventilation to the case.
Its an older case, no fan and the case is full open...put a AMD Athlon 64 fan, not the heatsink, and put it on the 1000's heatsink no difference, but same the heat is hot when you take it off, it is currently at 69º with the original fan and heatsink, fan is going at 5400 RPMS.
MX518
G15
650 W PSU
HaloCorn
Users browsing this forum: trendictionbot [Bot] and 2 guests
