Thermaltake CL-W0052 Tide Water All in One VGA Cooler
Postby ThEvil0nE » Fri Jan 06, 2006 8:14 am
Image Image
ThEvil0nE
Postby Tulatin » Fri Jan 06, 2006 10:04 am
Well, if you don't already have liquid cooling $78.99 isn't too bad to cool the GPU, but on the same token, it eats up a duet of PCI slots, not to mention witn unknown performance. After all, it's basically a tiny rad strapped to a radial fan, so i'd put about the same faith in this to dissipate heat as the Aquarius II had - which basically means when you hit (or pass) 100W, it poops out. Nevertheless, this could be quite a good one, but only time will tell.
Tulatin
