It is currently Fri Sep 21, 2018 9:36 pm
PostPosted: Fri Nov 11, 2005 1:18 am
I am building a PC, (Sempron 2500+), and I was wondering how much thermal compound needs to go between the CPU and heatsink? Also do I just put it on the middle of the CPU where the silver square is, or do I spread it all over the underside of the heatsink?
Dual Boot Windows XP Pro, Linux RedHat 9.0
Intel Pentium 4 630 (3.00 GHz, 800 MHz FSB, 2MB cache)
1 GB DDR2 533 MHz RAM
160 GB 7200rpm SATA HDD 8MB Cache
ATi Radeon X300 SE 128MB PCI-E
DVD-RW
Dual 17" TFT Monitors
PostPosted: Fri Nov 11, 2005 1:52 am
Just on the silver square. Use a small blob [about 1/4 of a pea!] and then put the heatsink on straight so it spreads.
Peace for its people,
Love in our lives,
Delight in the good,
Forgiveness for past wrongs,
And from now on a new start.
PostPosted: Fri Nov 11, 2005 7:44 am
The best instructions I have read to date are on the artic Silver website
http://www.arcticsilver.com/arctic_silv ... s_big2.htm
If you are spreading thermal compound I find a plastic foodbag over the finger works well for this.
PostPosted: Fri Nov 11, 2005 8:04 pm
webster, great link! :mb_thumbup::
so, basically, I've been doing about 5 things wrong all this time. :wink:
PostPosted: Sat Nov 12, 2005 10:16 pm
:roll: Noone reads my Cooling 101 I see.
Quote:
Once the HS/F is cleaned, apply a small amount of AS5 on the bottom of the HS/F in the area where the CPU core will be touching it. With your finger in a clean plastic bag or latex glove, rub the AS5 into the HS/F. This will fill in all of the micro valleys that are present no matter how smooth the surface.
:P
The Gift of Healing
Conscious Energy Meditation
PostPosted: Sun Nov 13, 2005 4:59 am
I'd have pointed people in that direction but the website has pretty pictures :P
