It is currently Sun Sep 23, 2018 10:04 pm
PostPosted: Fri Nov 04, 2005 6:22 am
I'm upgrading and going to buy a AMD Athlon 64 3700+ San Diego 1GHz (along with new MB, video card, etc...).
I've read that this 939 chips run cooler, but I cannot find what they are referencing. Is it to Intel chips or older AMD chips (like my Barton 2500+).
As you can see from my sig I run a Silentboost HSF w/AS5 for the thermal paste. Idle is around 42deg C, and load is around 47deg C (running Battlefield 2).
Do you think temps for my new 3700 will be around the same?
Is the AMD supplied (retail) heatsink/fan combo good enough? What about the thermal pad? Should I clean it off and just apply some Arctic Silver?
One last question... How long is Arctic Silver good for? I've got a tube I bought 2 years ago and only used it for that one build so I've got a ton left.
Thanks,
Matt
ASUS M2N-SLI Deluxe MB
AMD 64 X2 4200+ Socket AM2
Corsair TWIN2X2048 2GB Kit DDR2-800
Cooler Master Centurion Black Case
SFC Silent SF-650 2.0 650W PS
Plextor PX-760A 18X DL DVD±RW
2 x Caviar WD 250GB SATA Drives
eVGA Geforce 7900GT KO 256MB
PostPosted: Fri Nov 04, 2005 7:58 am
If you're not overclocking the stock is fine, if it wasn't why would they supply it?
The new chip will run about the same temps as present, maybe less. I have a feeling the silent boost won't fit the 939, but I'm not sure.
PostPosted: Fri Nov 04, 2005 11:23 am
Like Rob said the retail hs&f and thermal pad work well even up to moderate overclocking.
Your temps should be a little lower than the 2500 Barton even with the aftermarket hs&f you have.
PostPosted: Fri Nov 04, 2005 6:56 pm
Thanks for the info.
Matt
PostPosted: Fri Nov 04, 2005 7:05 pm
I have tubes of Arctic Silver that are 4 years old and they still work as advertised, so I wouldn't worry abou it, even though I couldn't find any info about it's shelf life. 8)
The Gift of Healing
Conscious Energy Meditation
