Silver foil on heat sink!
Postby Twisty » Mon Oct 24, 2005 3:12 pm
I have just reseated my flatmates P4 1.7Ghz HSF with artic silver. The existing compound had not been applied correctly and POST temps are now down from 55C to 35C!
A square of soft metal (prob aluminium) foil appeared to be stuck to the intel heatsink where I would usually expect to find the usual grey pad. I wanted to peel it off but the owner insisted it was kept; temps seem to be OK now anyway.
The question is what is this silver foil stuff? Is it just a different type of thermal pad? I would appreciate any enlightenment.
Twisty
Postby Tolemac » Mon Oct 24, 2005 9:57 pm
I've run into those before. It's a thermal pad, but the thermal stuff has dried up and gone away. :roll:
Nothing really wrong with keeping the aluminum square on there, but I remove 'em, clean up the botton real good and just use AS3 or 5. 8)
Tolemac
Postby Twisty » Tue Oct 25, 2005 3:52 pm
Thanks for confirming that for me. :mb_thanx::
Twisty
Postby Tolemac » Wed Oct 26, 2005 5:08 pm
:mb_thumbup::
Tolemac
