XP2500+ (Barton Core) Temps
Postby Toby B. » Wed Oct 19, 2005 3:11 pm
My server is running a bit hot I think. The CPU temp is at 47-50*C according to MBM. Case Temps are hovering about 42*C according to MBM. Room Temp is currently 77*F.... This is under Moderate load (Windows, Apache, MySQL, 2 IP Updaters, AVG Free Edition). These are what is running fulltime on this system...
I recently cleared the CMOS so the automatic shutdown temp defaulted back to whatever the defualt temp is (50-60*C IIRC).....
So any ideas on what a safe shutdown temp would be? BTW, I am using AS5 Thermal Grease too....
Toby B.
Postby DAVE1 » Wed Oct 19, 2005 3:33 pm
the maxiumum temp for the Barton Core
2500+ is 85 C so i would set it somewhere around there
Join team 33258 today!!
DAVE1
Postby ~Rob » Wed Oct 19, 2005 3:52 pm
dust bunnies maybe? Mines getting hot again, but I'm thinking of a new case instead, and new cooling of course
~Rob
Postby Toby B. » Wed Oct 19, 2005 4:27 pm
~Rob wrote:dust bunnies maybe? Mines getting hot again, but I'm thinking of a new case instead, and new cooling of course
Nah, no dust bunnies yet!!!! This heatsink has only been on less then 36 hours. Grant its only rated for a XP2400+.......... :oops:
Its so quiet though... 8)
Toby B.
Postby DAVE1 » Wed Oct 19, 2005 5:30 pm
doesn't it take a while for the thermal compound to perform optimally ?
i think i saw it on artics site
DAVE1
Postby Toby B. » Wed Oct 19, 2005 7:56 pm
DAVE185 wrote:doesn't it take a while for the thermal compound to perform optimally ?
Yes it does....
I went into the BIOS and the highest temp I can set the Auto shut down. So we shall see what happens now...
Toby B.
Postby Southwind25 » Mon Oct 24, 2005 10:43 pm
I'd set it to about 70/75 deg c just so I'd know if there was a problem before critical temps. You will usually know though because of lockups, BSOD, etc. anyway.
Southwind25
