It is currently Fri Aug 17, 2018 8:38 pm
 Post subject: side fan?
PostPosted: Tue Oct 18, 2005 2:59 pm
Built a system last year and set up the case fans like this: PS fan and another case fan just below it blowing out the back. The case also came with a side panel fan which I set up to blow in on the video card/processor area. Do you think this is the best set up or should I have the side fan blowing out too. Just curious. I'm not overclocking or anything and my temps seem ok. cpu=52, mb=28 according to ASUS probe software.
"A veteran... is someone who... wrote a blank check made payable to the United States of America for an amount “up to and including my life”. That is honor, and there are way too many people in this country who no longer understand it." - Unknown
PostPosted: Tue Oct 18, 2005 8:02 pm
If you don't have a front fan blowing cool air in, then the side fan is a must. 8)
The Gift of Healing
Conscious Energy Meditation
 Post subject: Re: side fan?
PostPosted: Wed Oct 19, 2005 3:03 am
I would recheck your temps though. Your CPU is a little high. I had to reflash my BIOS on my ASUS motherboard to get the correct readings.
Gerald Ford (1913 - 2006)
PostPosted: Wed Oct 19, 2005 12:50 pm
yea those temps seem a bit high, esp the processor...i have a simmilar cooling setup to yours and i run in the 20's to 30's....mid 30's under heavy processing, chances are your mobo is giving bad readings, i would flash the bios as greytrains said...update your chipset and flash bios if you havnt
PostPosted: Wed Oct 19, 2005 4:28 pm
Thanks for the responses. I might also point out I'm using the stock retail hs/f on the cpu. That temp will drop to 48-50 as the weather cools off and it gets colder down here in the basement. :roll:
