It is currently Tue Sep 25, 2018 11:21 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Nov 09, 2005 4:14 pm
So what you're saying is that where you live, the normal laws of physics apply. :lol: Yup. You're right. Sorry, wasn't thinking.
But, you could get an external watercooler resevoir and put THAT outside the window, provided you let the machine run all the time and didn't let the water freeze! :wink:
PostPosted: Fri Nov 11, 2005 7:41 am
Well a good thing about a water system is as long as you have a powerful pump you can put the radiator almost anywhere and the hoses will be much easier to hide than an air duct.
As far as I am aware the critical 'dew point' where condensation occurs is when there is a temperature difference of about 10C, (depending on humidity) between an object and the surrounding air.
So putting the radiator outside may be going a bit over the top but if you are in an old house with a particularly cold/damp corner to place the radiator in then you could warm the area up a bit and reduce coolant temps by putting the radiator there.
I did once read an article where this guy dug a huge hole in his garden and buried a large water reservoir there to supply his compy with cool water all year round!!!
