Efficient fan/heatsink
Postby sylvester » Wed Sep 21, 2005 4:03 pm
P4 478 2ghz, good fan/cooler no more than 80ish mm high
sylvester
Re: Efficient fan/heatsink
Postby Toby B. » Wed Sep 21, 2005 4:09 pm
sylvester wrote:P4 478 2ghz, good fan/cooler no more than 80ish mm high
Hmmmm, what is it you are looking for? A recommendation for a new Heatsink/fan combo?
Toby B.
Postby sylvester » Wed Sep 21, 2005 4:19 pm
Got one of these antec/aria shuttle type cases and there ain't a lot of room for a fan/heatsink, 85mm high would be pushing it, the original fan is screaming pretty loud!
sylvester
Postby Sabrewings » Wed Sep 21, 2005 4:55 pm
I'll have to measure it, but a Swiftech MCX478 with a 92mm fan shouldn't be higher than 80mm.
Sabrewings
Postby Ryn » Wed Sep 21, 2005 7:16 pm
Most of the people that i know uses Zalman CNPS 7xxx. It sure is short but is kinda wide so be sure that it will fit your mobo.
Ryn
Postby sylvester » Thu Sep 22, 2005 1:47 pm
Its an intel d845grg board, there's not a lot of room in the case even with tidy wiring. Not sure the zalman would fit, pretty tight.
sylvester
Postby Southwind25 » Thu Sep 22, 2005 2:30 pm
You might look at
http://www.svc.com/sp441b0-f-16.html
and see if it will work for you.
Southwind25
Postby Tolemac » Thu Sep 22, 2005 4:24 pm
Good call Southwind. That should work nicely. 8)
Tolemac
Postby Mr T » Thu Sep 22, 2005 8:54 pm
Coolermaster aquagate
Use this in one of my Antec Arias on a p4, otherwise stock HSF's work just fine...
Postby sylvester » Fri Sep 23, 2005 10:51 am
Thanks for the replies, I'll do a bit of measuring before deciding, hopefully won't need the aquagate as its only a 2ghz :D
Mr T is your pwr supply noisy, kinda tinny sounding on your antec aria case?
Apologies Mr T, its a screeming h/drive, in a small case its difficult to pinpoint the noise, new h/drive tomorrow!
sylvester
