It is currently Tue Aug 14, 2018 11:17 pm
 Post subject: is it a dumb idea
PostPosted: Tue Sep 20, 2005 9:13 pm
I get how to overclock and I know some about what things I need to do to do it, but I have a 2700+ 2.17 GHz, is clockin it to 2.4 a stupid idea or is that a perfect bump up 4 that proc? I have koolance water cooling, gpu in the loop to 6800.... temps cpu is reporting now aren't probably accurate as its first in the loop but still heat from the gpu last in the loop adds a little, but anyway 79 or 80 degrees ambient 38 39 C, 77 ambient 34 35 C
Enermax 600 Watt PSU
AMD Athlon XP 2700+
1 GIG DDR400 Corsair Ram
Asus A7V880 (VIA KT880)
BFG 6800 OC GF6
Koolance (CPU,GPU)
Western Digital 60 Gig SATA HD
PostPosted: Wed Sep 21, 2005 9:13 am
I don't know if your chip would take the voltage, cooling would be ok until 2.3 Ghz I should think at least. Best way is to take it step by step and find out
PostPosted: Wed Sep 21, 2005 9:22 am
If you see smoke and flames, then its a good idea to stop.
Good luck.
PostPosted: Wed Sep 21, 2005 4:26 pm
Buy a faster cpu, its cheaper than aircon to bring the ambient down! :)
