It is currently Sat Sep 22, 2018 9:16 am
PostPosted: Thu Sep 15, 2005 8:23 pm
HollowPoint69 wrote:
Stock heatsink/fan is fine.
8O You didn't really say that, did you?? I have a 9800 Pro and that was the first change I made with it. The stock heatsink/fan are an absolute joke on those things. ATI is really cutting corners and dollars by using that crap. Low grade aluminum and a small, no CFM fan. :roll: Indeed, the bottom of the card used to get very hot (had to test it out first to make sure it would be compatible with my ghetto rigged system :lol: ) so I reinstalled the Water Chill and now I can touch the bottom of the card and it's barely warm. 8)
The Gift of Healing
Conscious Energy Meditation
PostPosted: Fri Sep 16, 2005 2:25 pm
Quote:
Ryn wrote:
I would suggest Jetart JACSH1. It's probably the best gpu hsf out there.
It's water cooled...
wrong:it isn't water cooled, it's regular...
PostPosted: Fri Sep 16, 2005 2:31 pm
Whoops, I am a dumbass. I thought that it was a copper GPU water block, but the fan was just really clear Laughing
Good find Ryn.
Read thread please.
PostPosted: Sat Sep 17, 2005 12:52 pm
tell me something new ...
PostPosted: Tue Sep 20, 2005 4:05 pm
just use a silencer from arctic cooling, relocates the toastiness to a stream of air out the case rather than the card.
