It is currently Mon Sep 24, 2018 11:34 am
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Thu Feb 05, 2004 6:46 pm
Something you should know, the decibles aren't everything. If it is high pitched it will drive you nuts!
I have a belly button
PostPosted: Thu Feb 05, 2004 7:37 pm
True, but won't that mainly be caused by air resistance?
PostPosted: Thu Feb 05, 2004 7:39 pm
sometimes. Other fans just have a damn whine due to rpm.
PostPosted: Sat Feb 07, 2004 1:47 am
My case was full of those "stamped" fan grills in its chassis. I have cut out (with small cutters) five of them (2 rear, 2 mobo side, 1 front) and sound levels have dropped considerably (though it is still loud due to the amount of fans I have) I now run three at low power (for hdd cooling) and the remainder at high power...
PostPosted: Sat Feb 07, 2004 2:49 am
Go to i think its overclockers.com, but one of the guys there, made a prog that calculates DBA from ur case fans.
PostPosted: Sat Feb 07, 2004 3:40 am
One of my cases has one of those stamped grills which probably blocks half of the air that is supposed to go through it. One of these days, I should cut that grill out and use one of those wire ones instead. That case is fairly flimsy, though; what would be the best method to go about cutting out the old grill?
What is Folding?
Wookie's F@H Site
PostPosted: Sat Feb 07, 2004 3:53 am
I used a small pair of snips - (ones that have broad cutting blades that taper to a point), and just chomped out all the sections between grill at its outermost edge, then sanded and placed a chrome fan grill over the hole.
(An edit to my last post: all low voltage fans are now running at full steam again so noise is back up a bit once more)
PostPosted: Sat Feb 07, 2004 4:04 am
Heres a couple links worth looking at:
http://www.directron.com/directron/noise.html
http://www.gizzo.8m.com/fans/
PostPosted: Mon Feb 09, 2004 6:10 am
Thanks for the links Wookie. 8)
The Gift of Healing
Conscious Energy Meditation
PostPosted: Thu Sep 08, 2005 7:20 am
If anyone's still wondering, 1dB is barely noticed; 10dB equals 10 times the sound pressure but sounds twice as loud; doubling sound sources makes about a 3dB difference.
