A question of Sound
A question of Sound
Postby ~Rob » Wed Feb 04, 2004 7:14 pm
Just a general ponder, but if I have a 20dB fan and add another, is the total noise now 40dB???
Also, am I right in thinking that for every 1dB increase it is 10x louder? I heard it somewhere but I might have been dreaming.
Thanx in advance
~Rob
Postby triggerhappy41 » Wed Feb 04, 2004 7:16 pm
Youre right about the 10X louder part, but as for the sound "adding up" I dont really think so. It could be tho.
CPU=AMD Athlon X2 3800+
RAM=Corsair XMS DDR400 1GB 2-3-3-6 Timings
MOBO=ASUS A8N-E
VID=EVGA GeForce 7950GT
HDD=74GB WD Raptor
triggerhappy41
Postby ~Rob » Wed Feb 04, 2004 7:21 pm
Cheers mate. I was more unsure about the 10x bit and I'm not 100% on the adding but I can hear my noisy fan over the others so maybe not.
me confused, I'm just going to be adding about 3-4 new fans, hopefully around the 20dB mark and that would make 60-80dB louder than it is now!!
~Rob
Postby Tulatin » Wed Feb 04, 2004 7:21 pm
They do add up, but it's a veery small increase. The biggest increases will come from things blocking airflow - after all - notice how much louder case fans are when put on those damn stamped out sections versus on they're own?
Tulatin
Postby ~Rob » Wed Feb 04, 2004 7:24 pm
Tru, tru.
I will be hacking about my case + PSU soon just to stop air resistance. Bloomin annoys me that!!
What increase will I get by adding another fan of the same loudness??
~Rob
Postby Tulatin » Wed Feb 04, 2004 7:26 pm
Something like .1 db - not a whole hell of a lot. As to the hacking, i used wire cutters to remove stamped grills before - very painful, use tin snips!
Tulatin
Postby ~Rob » Wed Feb 04, 2004 7:29 pm
Just had a look at the back of the case and the PSU will come apart easy, but the rear fan has loads of 2mm holes. Did they want to make it noisy?? That I'll probably leave alone!!
The front as far as I remember is the same, but a spring clean is called for. Maybe next weekend!!!
~Rob
Postby Tulatin » Wed Feb 04, 2004 7:31 pm
the front makes ne most noise, and can you wait a day or two to do the psu so i can show you my molex method.
Tulatin
Postby ~Rob » Wed Feb 04, 2004 7:34 pm
Yeh, there's no rush. I have to fix the girlfriends PC first!!
As long as its cheap and an easy bodge ahem, proffessional job, I'm all for it!!
~Rob
Postby Tulatin » Wed Feb 04, 2004 7:34 pm
meh, it'll be professionally 'nuff.
Tulatin
