It is currently Wed Aug 22, 2018 12:21 am
 Post subject: p4 2.2 cooling
PostPosted: Thu Jul 11, 2002 3:08 pm
could you tell me what a good fan and heat sink would do a good job at cooling for a p4 2.2 and where is the best place to get it and would i be able to use the same mounts that are already installed on the mb to install the new one
thanks
PostPosted: Fri Jul 12, 2002 5:08 am
$24.00 Heatsink- Thermalright AX478 - http://www.newegg.com/app/ViewProduct.a ... 444&depa=1
$15.00 Heatsink Fan- Vantec Tornado Double Ball-Bearing - http://www.newegg.com/app/ViewProduct.a ... 453&DEPA=1
Only if you don't mind the 50+ dba's
PostPosted: Fri Jul 12, 2002 10:16 am
What about the thermaltakes Volcano7= that every one is talking about
PostPosted: Fri Jul 12, 2002 10:42 am
The Volcano 7+ is the most versatile heatsink on the market. It will provide excellent cooling for your P4 along with using Arctic Silver III Thermal paste. 8)
The Gift of Healing
Conscious Energy Meditation
