It is currently Thu Jan 17, 2019 11:57 pm
 Post subject: stupid newbie question
PostPosted: Sun Jul 07, 2002 12:04 pm
i looked around and couldnt find an answer to this, but its probably because its so obvious no one needed to ask it, but this is my first computer build and i dont want to screw up.
so the question:
i have an AMD 2200 and a volcano7+, a copper shim and some arctic silver3
i know the arctic silver goes on the cpu die, but does it go on the shim as well?
and am i supposed to completely cover the volcano side and then whipe it off?
also if i have no plans of overclocking (if its even possible on this chip, read that it isnt) how much do i need to worry about fans? I have two plus the volcano and the power supply fan, and was thinking of getting two more
thanks!
PostPosted: Sun Jul 07, 2002 2:14 pm
Ok the as3 only goes on the die of the cpu not on the shim, only apply a very thin coat of as3 ( like Tolemac says a paper thin coat ). The shim is only a spacer to protect against the chance of cracking the cpu when installing the heatsink and fan. I suggest at least 1 intake and 1 exhaust fan. If you have room to fit 4 then use 2 intake and 2 exhaust. I hope this helps :) .
PostPosted: Sun Jul 07, 2002 7:55 pm
thanks that helps a lot, ive been looking at the damn thing not wanting to screw up, now i can get on with it
:D
