AC
AC
Postby chewie432 » Sat Jul 06, 2002 5:25 am
What is the best water cooling kit out on the market as of today?
chewie432
Postby Porphyria » Sat Jul 06, 2002 7:00 am
I think the Innovatek is the highest performance kit out. Koolance is very good and cools well. Swiftech cools a little better than the Koolance but it cannot be used to water cool components other than the CPU whereas the Koolance has component coolers for the graphics card, hard drive, northbridge, and other parts. I think Tom's Hardware has a review of the Innovatek and Swiftech. http://www6.tomshardware.com/cpu/02q1/020102/index.html
Kids in a fast lane living for today
No rules to abide by and no one to obey
ID This Quote
Porphyria
Postby andrey » Sat Jul 06, 2002 7:34 am
the Innovantek would be the "best" to put with cooling efficiency, the problem is that the parts come seperately, and you'll have to drill some holes somewhere, for example, where are you going to put the radiator? :)
Swiftech is pretty good, but then again, last I checked they only cooled the CPU. they come as a case set, you get the case and the cooler.
Koolance, on the other hand, is the best for beginning watercoolers, or for people who don't want to drill through everything. (me). you get the case, and you order what coolers you want. you can get a CPU cooler, a video card cooler, a motherboard chipset cooler, and a HD cooler. www.koolance.com
________
medical marijuana dispensaries
andrey
Postby ThEvil0nE » Sat Jul 06, 2002 12:57 pm
Water cooling is really good but there are a few good air cooling(HSF) around that performs well and almost about the same cooling effect as water cooling :idea: :twisted:
Image Image
ThEvil0nE
Postby andrey » Sat Jul 06, 2002 2:33 pm
at the expense of NOISE.
________
Yamaha QT50 specifications
andrey
Postby ThEvil0nE » Sat Jul 06, 2002 6:34 pm
not really...if you use an 80mm hs fan. I think the radiator would be more intrussive than the fan.
The only day I would be convinced to water-cool my sytem is when the water-cooling manufacturer will warrant your system if ever their product would "screw-up" :roll:
Image Image
ThEvil0nE
Postby andrey » Sat Jul 06, 2002 7:01 pm
well the origional question referred to watercooling.
a relatively simple installation would be the Koolance. for complex installation but slightly better cooling performance, check out Innovantek.
________
oxygen vaporizer
andrey
Postby chewie432 » Mon Jul 08, 2002 4:44 pm
But with some good fans can you get your computer to a temp of about 40 degrees?
chewie432
Postby Porphyria » Mon Jul 08, 2002 5:01 pm
It depends on the ambient temp. If you put your computer in a refrigerator you wouldn't need fans. :P 40C is attainable with a good ambient temperature coupled with good case ventilation and a quality hsf.
ID This Quote
Porphyria
