It is currently Sun Sep 23, 2018 4:53 am
PostPosted: Fri Jul 05, 2002 4:28 pm
Which of the two would cool my processor more, if my ambient temp was a steady 72*F? I read the review of the Arkua and there was a 6*C difference between it and the stock hs/f. I can't find any such comparisons for the Volcano7+ though. Please recommend the one that will cool the most :)
Thank-you all
PostPosted: Fri Jul 05, 2002 9:43 pm
well i use the arkua and it has been nothing but smooth sailing so i will recomand the Arkua cooler
PostPosted: Mon Jul 08, 2002 7:28 pm
OK...where can I get one of those arkua for XP and what model? :twisted:
Image Image
PostPosted: Mon Jul 08, 2002 8:36 pm
at newegg, where else? :)
http://www.newegg.com/app/ViewProduct.a ... 577&DEPA=1
second to bottom for AMD XP, bottom one for P4.
________
Honda RC114
PostPosted: Tue Jul 09, 2002 4:12 am
Is that it? I don't think so. what model?
UPDATE:
OK found it at their website. I just want to see that "thing" :twisted:
Image Image
