It is currently Tue Sep 18, 2018 11:49 am
PostPosted: Thu Jul 04, 2002 1:35 am
Hey Peeps
Just a quick one here to ask all you guys if it is totally necessary to have a fan on the north bridge? i have a small fan on it (came with the comp) but it is making a huge high pitch whining sound. Is is safe to disconnect it? its not gonna permanantly damage it is it?
Also, will it make any difference in terms of overclocking?
My system:
gigabyte ga7dx
512 ddr
gf4 4400
athlonxp 1800
Cheers
JonnyP
PostPosted: Thu Jul 04, 2002 8:39 pm
might want to give gigabyte a call about it- possible that you can get a replacement fan from them.
PostPosted: Fri Jul 05, 2002 7:14 am
cheers
i thought of that and it doesnt really bother me about contacting them, i can get a replacement easily, i just wanna know if it will be damaging to the northbridge if i DONT have a fan.
I'm sure ive seen NB's without fans so if anyone can gimme an answer....
PostPosted: Fri Jul 05, 2002 7:48 am
My GA-7VRXP didn't come with a fan or HS for the NB but the board does have a socket where I can hookup a fan.
Image Image
PostPosted: Fri Jul 05, 2002 2:16 pm
Cheers
I think i can safely take it off now, without doing any permanant damage to the system.
Post if you think different!!!!!
PostPosted: Fri Jul 05, 2002 2:36 pm
If you OC, It would be better and a must to have that cooling thing on.
Cool=Good
Hot=Bad
One cool syetem=Happy system
COOL :arrow: 8)
Image Image
