It is currently Thu Oct 18, 2018 10:08 am
 Post subject: Koolance water cooling
PostPosted: Mon May 13, 2002 10:38 am
:P
I finally got the Koolance case in, I will post my results when I get it all together, and give it a good gaming workout.
...case.htm what came in the box. Enjoy!
It took some time to get it all together.
i let it run for 2 hours and the temperature only got up to 42 for the CPU and 40 for the system.
But the LCD on the top had a reading of 32???
AMD 2100+
MSI Geforce4 Ti4600
Gigabyte GA-7VRXP
512MB DDR 2700
60GB
16x DVD
32x Burn
PostPosted: Tue May 14, 2002 8:18 pm
the LCD readout is basically the heat transfer heat, since it is located between the CPU and the heatsink, while the motherboard temp is located under the CPU.
how much did the koolace case cost all together?
________
MX-5
PostPosted: Wed May 15, 2002 12:26 pm
it was a total of 410 with shipping and the CPU and Chipset Water Blocks.
AMD 2100+
MSI Geforce4 Ti4600
Gigabyte GA-7VRXP
512MB DDR 2700
60GB
16x DVD
32x Burn
PostPosted: Wed May 15, 2002 9:27 pm
so you got the large case, not the midsize one? does it fit the Socket A alright?
________
silversurfer vaporizer
PostPosted: Thu May 16, 2002 6:21 am
my board fit with no problem.
the hardest part was the hose clamps and putting the water in.
AMD 2100+
MSI Geforce4 Ti4600
Gigabyte GA-7VRXP
512MB DDR 2700
60GB
16x DVD
32x Burn
PostPosted: Thu May 16, 2002 7:30 am
I guess the important question is, is it worth it? lol :)
thinking about getting it for my birthday..
________
Plymouth Breeze history
PostPosted: Thu May 16, 2002 11:54 am
yeah for me it was, I like to run my computer 24/7 but my room is upstairs and without water cooling i would not be able, it would just been to hot. had a scare about 10 min. ago the power cord for the pumps came loose and it was running hot, good thing it beeps like crazy to let you know.
AMD 2100+
MSI Geforce4 Ti4600
Gigabyte GA-7VRXP
512MB DDR 2700
60GB
16x DVD
32x Burn
