Thermaltake Case Fan
Post Reply
chmod
Post by chmod »
I have a thermaltake xaser II tower and I need another case fan, I am having some trouble finding it...please help
Johnny Mnemonic
Post by Johnny Mnemonic »
It shouldn't be anything special required. Fans typically come in 60x60mm, 80x80mm, 90x90mm, and 120x120mm. So if you just need a 2nd fan, measure what you have, and make sure the 2nd slot is the same size. Then just about any computer electronics store should have it. Comp USA, fry's electronics, your local hardware shop, maybe even radio shack. Or you can goto www.newegg.com to order some. I got a few cheap ones off e-bay, but they aren't the highest of qualities (they were cheap though)
[color=white][size=59]0100101001001101[/size][/color]
[url=http://profile.xfire.com/thiefmnemonic][img]http://miniprofile.xfire.com/bg/sh/type/2/thiefmnemonic.png[/img][/url]
chmod
Post by chmod »
sorry I wasnt specific, I am looking for another thermaltake fan, the same one that came with the case. ( one of them broke ), but thanks for your help...I couldnt find it on newegg :?
tonycarr
You can find almost any ...
Post by tonycarr »
type of case fan @ this link , good company , order from them all the time .
http://www.nexfan.com/43/cat43.htm?606
[color=red]E Pluribus[/color] [color=blue] Unum[/color]
chmod
Post by chmod »
cannot find server...
tonycarr
I notice the ...
Post by tonycarr »
link ( site ) I posted , has several sizes & types of ThermalTake case fans . Link works fine for me , ( IE 6 ) . Try www.nexfan.com . Click on case fans . Site is not the fastest in the world but worth the wait .
Good Luck .
Post Reply
