Water Cooling Case suggestions
Postby Juggalo23451 » Thu Jan 06, 2011 7:17 am
Dimensions are listed below of each case and prices to. Click on dimensions to see the Case and more info
Cosmos S
24.72" x 10.47"x 23.54"
199.99
Haf 932 360 rad internally
22.70" x 9.00" x 21.50"
139.99
haf 922 I have seen a 360 thin rad mounted internally
22.20" x 10.00" x 19.70"
99.98
ATCS 840 360 rad internally
24.80" x 9.57" x 22.83"
179.99
Corsair Obsidian 360 internally
24.00" x 9.00" x 24.00"
299.99
Silverstone TJ07 480 rad bottom or 360 rad top and another rad in the bottom
22.24" x 8.66" x 22.05"
359.99
LIAN LI PC-P80
25.24" x 8.66" x 24.92"
369.99
ABS Canyon 695 can fit a 360 rad in front or 4 x120mm rad
17.00" x 9.10" x 26.80"
499.99
ABS Canyon 595 can fit a 360 rad in the front
17.00" x 9.90" x 23.50"
299.99
NZXT Tempest EVO
depth:562mm,H:521.5mm,W:211.5mm
109.00
Haf X
(L x W x H)[23.20" x 9.10" x 21.70"
199.99
Monitor 2343 samsung x3= 6144x1152
loop 1
res/mcp35x-rx480-gpu-gpu-rx480 white tubing
loop 2
res/mcp35x-rx480cpu-chipset-res
Juggalo23451
