It is currently Tue Dec 11, 2018 5:31 am
 Post subject: Compressed air
PostPosted: Tue Aug 31, 2010 2:23 am
Is there any good alternative to the cans of C02 that can be used for clearing dust and hair out of electronics. I remember hearing something about vacuums causing too much static charge on components.
PostPosted: Tue Aug 31, 2010 5:07 am
standard compressor with adjustable pressure valve.
PostPosted: Wed Sep 01, 2010 5:59 pm
Vaccums cause static, compressed air uses a liquid propellant that can (and often does) spray a fine mist on your electronics. Personally, I just use a lint-free cloth and an artist paintbrush of the right size (I have several) dipped briefly in denatured alchohol then swabbed out with a clean dry brush.
Otherwise, yeah, $50 air compressor from WallyWorld.
Faster than the speed of snot
PostPosted: Wed Sep 15, 2010 3:08 pm
You can get non static vacuums, but they are quite expensive.
I have a 2HP compressor, but it is too much hassle for me to use that on PC's - I just carefully use a normal vacuum and bear the risk.
