It is currently Sun Jan 20, 2019 11:44 am
 Post subject: Need help removing fan
PostPosted: Fri Oct 30, 2009 12:47 pm
Hi
I recently decided to upgrade my power supply for my computer but in order to create the space necessary to remove my current one i need to temporarily remove a fan attached to the motherboard. The fan is an ACER H1.3670C.001 REV B FOX CONN. I only need to remove the fan (not the heatsink) and see no obvious way to take it off. Any help would be appreciated.
Thanks
PostPosted: Sat Oct 31, 2009 12:24 am
I suspect the motherboard is on a tray and can be moved to the side. I also suspect this is a branded computer, so which brand/model is it, we might be able to find the disassembly instructions.
