It is currently Sat Sep 22, 2018 1:37 pm
PostPosted: Mon Dec 29, 2008 1:21 am
I'm looking for the best temperature monitor for CPU, GPU and motherboard, other components would be a bonus.
I would like constant readability, so either a program running inside Windows (Vista Ultimate 32bit) or a 5.25" hardware LCD component. If it helps, my motherboard is an Abit IP35 Pro XE and my CPU is a Core 2 2.66Ghz - E7300.
PostPosted: Mon Jan 03, 2011 12:43 am
Core temp for CPU. I use msi afterburner for gpus
PostPosted: Mon Jan 03, 2011 8:59 am
riva tuner has some pretty good feedback graphs as well as knows how to overclock most vidcards...
http://downloads.guru3d.com/RivaTuner-v ... d-163.html
highly customizable.
my main rig...
asrock 970 extreme3
AMD FX-6300 Vishera CPU
zalman cpns5x performa hs/fan
powercolor ax7750 1GBK3-H vga
antec neo he 650r
Samsung 840 EVo SSD 120 GB
lg wh14ns40 bd burner
PostPosted: Mon Jan 03, 2011 10:27 am
Riva tuner is kinda out date though. Evga precision is pretty much riva tuner for example
PostPosted: Mon Jan 03, 2011 11:59 am
On this page you can download RivaTuner v2.24c.
Version: 2.24c
Publisher: Unwinder
Date added: 2009-08-23 13:47:39 :!:
yeah i guess it is kinda old now. i stopped using it back when i stopped using nvidia graphics cards. it was really good for the 6000 series back in the day!
my main rig...
asrock 970 extreme3
antec neo he 650r
