It is currently Sun Jan 20, 2019 11:32 am
PostPosted: Wed Aug 27, 2008 3:51 pm
Image Image
Yes Yes, I'll finally be putting this build together this weekend, lol and I agree...it's about darn time. ha!
I'll be populating all available 120mm spots with Antec TriCool fans; ie, 2 front intake filtered and 1 side intake not filtered. It already has 120mm back exhaust and 140mm top exhaust.
My main question relates to the placement of my single SATA HD. I purchased:
Scythe SCY-HDS2 "Anti-Vibration HDD Stabilizer 2" for 3.5" HDD
http://www.newegg.com/Product/Product.a ... 6817984001
so I could mount the HD in a 5.25" bay if I wanted to and if there is any noise-dampening as a result, that would be a bonus.
I planned on mounting my SATA DVDburner in the topmost 5.25" bay.
Basically, I have two choices:
1-Mount HD in 3rd from top 5.25" bay with no fan support
2-Mount HD in 2nd from bottom 3.5" bay and have fan support
This will be my first SATA HD...yes, I am a SATA-virgin, it is true and I'm not sure about cooling requirements. The Antec 300 case does have a bezel all the way up the front but I would like to keep it closed on the top bays (lessen noise) except for the DVD, of course. An additional option, if I put the HD in one of the 3.5" bays is to put the DVD in the middle 5.25" bay to allow open air above and below it, even though there will be no fan blowing on it.
As I said earlier, I do have a spot for a 120mm in the side panel and have a fan for it. Wasn't sure if I should use it or cover the area to provide better airflow, which I "use to" read (years ago, lol) created a better front to back airflow.
I also should mention that I opted to use a top-down HSF:
COOLER MASTER RR-CCH-PBU1-GP 120mm Sleeve CPU Cooler
http://www.newegg.com/Product/Product.a ... 6835103046
but got it when it was onsale at their sister site, chiefvalue.com. It is well-reviewed and tests very well; ie, temps and noise.
Well, there you go...always too much information given and multiple questions, lol. Yep, that's me. ha! Just know I always appreciate your feedback and certainly will doing this new build.
THANKS, everybody.
AMD 940 | Abit AN78GS | 4GB GSkill 1066| EVGA 9800 GTX+ SC | Corsair VX550 | Sunbeam CCC | Antec 300
i7-980X | GA-X58-USB3 (rev. 1.0) | Corsair D GT DDR3-2000 6GB | MSI GTX 480 | Corsair 750W | True Black | CM Storm Sniper
PostPosted: Wed Aug 27, 2008 5:50 pm
I have that same case that I am using for my building. do you really think I need might need the HDD noise dampaner also?
Gateway MT6707 Notebook
Intel Pentium Dual Core T2060 1.6 GHz
Memory 2048 MB 533MHz DDR2 SDRAM
Intel Graphics Media Accelerator 950
224 MB shared video memory
High definition audio 2 channel
160 GB HD
8X Multi-format dual layer optical drive
802.11g wireless LAN
4 USB 2.0 ports
One VGA port
One S-Video
One IEEE 1394
One PCMCIA Slot
If you have done a transaction with me, please fill out my heatware. http://www.heatware.com/eval.php?id=64039
PostPosted: Thu Aug 28, 2008 12:25 pm
I would mount the hard drive on the bottom half of the drive bays, SATA connectors on a motherboard usually are at the bottom, that way you don't have a sata cable running from the bottom of the board to the top of the drive bay.
I'm all about wire management :)
Intel Core 2 Duo E6750 3.8ghz
8800 GTS 640MB
Crucial Ballistix 2GB DDR2 800
Gigabyte DS3R
PostPosted: Fri Aug 29, 2008 10:04 am
Thanks, Rocky.
Kyle...the primary reason I got the dampener was so I would have the option of mounting the SATA HD in the 5.25" bay, wasn't so much about the dampening effect.
PostPosted: Thu Sep 04, 2008 8:49 am
I think you will be best served with the hard drive as low as possible and in direct path of the air flow, Also agree on closeing off the centre vent as the front to rear will have less turbulance. It is always better to have a slight positive pressure inside the case as this prevents dust from being drawn in through your DVD orifice and contaminating the lens.
PostPosted: Fri Sep 05, 2008 2:16 pm
Thanks for the input, Jimmy.
I think I will give the "closing off the vent" a shot. I'll take a look at the system temps and if I don't like what I see, I have the TriCool 120mm to fill it.
On positive pressure, I agree with that. Not sure I will be able to achieve it, though. 2x120mm in the front, 1x120mm back, 1x140mm top, and the PSU with the 120mm. So it looks like I'll be putting more out than in. My whole reason for using the Antec 300 case was so I could use more fans and run them at lower speeds to have the same airflow as less fans at higher speeds. But I can always set the 2 out's to lowest of three settings and the two front intake to second setting. We'll see how it goes on the noise level.
Oh, just got back from hardware store, needed to pick up some cable ties, I was out. I did not go modular but do have sleeved cables on my Corsair 550VX. And I picked up a couple of these in a larger size for under $2:
Why have I never bought them before for a build? They are perfect for putting one at the bottom side wall (mobo fits on) just to the left of the hd racks and another about 4" from top. Is large enough to fit 4 sleeved cables in, I believe and perfect for routing your Optical Drive cables (SATA and power) and running your cpu power cable up. I know I know...you guys already use these things probably but it just hit me today. lol
Still have not decided on placement of SATA HD yet...am taking all the advice via replies in...thanks for all of them.
EDIT: Did not even need the ties I bought or the little hook thingies, either, lol. I would take them back for a refund but I'm sure if they are sitting on the shelf, I'll soon find a use for them elsewhere.
Not using the side fan right now, have it closed off. System temps are at 33C and that is with my 8800GS single slot video card now installed. I am running the 2 front, 1 rear, and 1 top fan on low. If I oc the videocard, I may have a need to increase those fan speeds to medium but even then, it is a very quiet build.
