It is currently Wed Sep 19, 2018 9:04 pm
 Post subject: X2 4200+ temps
PostPosted: Sat May 10, 2008 8:22 pm
are these temps what they seem to be? it's non-oc with stock amd cooler...
Image Image
PostPosted: Tue May 13, 2008 7:48 pm
I would confirm your readings in the BIOS. Some of those readings look low for a stock cooler. The stock cooler for AMD is good but not that good. What is the rest of your setup? How long was your system running before you took those readings. Unless you are running your system in a nitrogen bath you do not want any temps below zero. You will have a condensation problem in your system.
Gerald Ford (1913 - 2006)
PostPosted: Mon Jul 07, 2008 10:41 pm
Download coretemp, will give you accurate temps. Your temps don't look right.
Intel Core 2 Duo E6750 3.8ghz
8800 GTS 640MB
Crucial Ballistix 2GB DDR2 800
Gigabyte DS3R
