It is currently Fri Jan 18, 2019 6:23 pm
 Post subject: Overheat problems
PostPosted: Sun Jan 20, 2008 7:17 am
My PIII system has a bad fan on the slot style CPU. Is there a way I can replace the fan with out damaging the CPU? I have had to resort to an external fan .
Gerald Ford (1913 - 2006)
PostPosted: Thu Jan 24, 2008 3:46 pm
Is anybody out there still using this style CPU?
PostPosted: Thu Jan 24, 2008 5:36 pm
I'm not.
PostPosted: Thu Jan 24, 2008 5:56 pm
I have to keep this system running for a few more months. Once I get my other motherboard fixed I can retire this system. I would like to keep it for back up though. Hence the reason I would like to fix the fan.
PostPosted: Thu Jan 24, 2008 7:14 pm
if the fan is integrated into the slot component that contains the die, it is probably best to leave it alone... a high cfm case fan blowing directly through the same area as the old fan might keep it cool enough to avoid damage...
PostPosted: Thu Jan 24, 2008 7:20 pm
Thats what I figured and hoped you would not say. Oh well, it is about time I got rid of that system anyway. :( :roll:
PostPosted: Sun Mar 09, 2008 10:32 am
BANNED!
What is a slot style cpu? I am quite curious on this one.
PostPosted: Sat Apr 05, 2008 10:59 pm
You can easily take the CPU out of the slot (slots were a lot easier than the socket 370, no risk of putting a screwdriver through the motherboard).. Then you can replace the fan itself, or even repair it...
PostPosted: Mon Apr 07, 2008 1:57 pm
I will try that once I get my other system up and running.
ImageSource
Users browsing this forum: BLEXBot [Bot] and 1 guest
