Noctua's NT-H1
Noctua's NT-H1
Postby ThEvil0nE » Wed Nov 14, 2007 1:33 pm
Got an email from noctua and thought it would be great to share it...
I've also made bold on what caught my interest most... "drop and install" :D
Vienna, 13th November 2007 - Noctua presented today a new premium-grade
thermal compound for enthusiasts who demand both exceptional performance
and maximum ease of use: NT-H1 is a hybrid compound of different
micro-particles that allows for minimum thermal resistance, excellent
ease of use and outstanding long-term stability.
"Many current TIM solutions have drawbacks either in terms of
performance or ease of use", explains Mag. Roland Mossig, Noctua CEO.
"Enthusiasts in particular, who frequently change their coolers, demand
both first class performance and trouble-free handling though. Our NT-H1
combines these two features and provides all the performance,
reliability and quality that Noctua users have come to expect from our
NT-H1 exhibits extremely low thermal resistance as well as excellent
pliability and spreadability. As a result, the compound is not only
highly efficient but also very easy to use because there's no need to
smear it over the heat-spreader: Put one drop of NT-H1 onto the centre
of your CPU, install the cooler and that's it! NT-H1 provides top
performance right from the start and doesn't require a longer "burn-in"
If you happen to make a mess, that's no problem at all: NT-H1 is
not electrically conductive and fully compatible with all materials
commonly used in PC environments.
In addition to its excellent performance and handling, NT-H1 provides
decisive advantages in terms of reliability and long-term stability:
Thanks to its exceptional curing, bleeding, dry-out und thermal cycling
characteristics, NT-H1 can be used for several years without any problems.
NT-H1 is not only suited for air and water cooling, but also for use
with compressor coolers: Even at the very lowest temperatures, the paste
delivers full performance and remains easy to clean off.
Price and availability
NT-H1 is available with immediate effect in syringes of 1.4ml, which is
sufficient for at least 15 applications. The suggested retail price is
EUR 7.99 / USD 8.99.
More information: ... =13&lng=en
Specifications: ... g=en&set=1
Photos: ... r=0&lng=en
Image Image
Postby sbrehm72255 » Wed Nov 14, 2007 2:16 pm
LOL....Got the same email as well, sounds like some pretty interesting stuff, might have to give it a try one day...............;)
