It is currently Tue Dec 11, 2018 5:32 am
 Post subject: Best case fans
PostPosted: Mon Oct 15, 2007 9:15 am
I'm looking for the best 120mm case fans. By best i mean air flow to noise ratio. I want to have a silent case but still cool. I don't overclock or anything but i want to have lowest temps for reliability purposes. If anyone has any recommendations as to what brands are quieter or not that would be helpful.
Thanks
PostPosted: Fri Nov 23, 2007 11:08 pm
The ones that I use all came with my case (250MM in front, 360MM on the side) but I do use a 120MM in the back: http://www.newegg.com/Product/Product.a ... 6835129246
It works for me, it pumps LOADS of air, and it isn't too loud. (then again, I can sleep through anything, so it may or may not be too loud for you)
People who have gone through Starfleet academy should be taught how to fix everything. Even a Roman aqueduct.
PostPosted: Thu Nov 29, 2007 2:04 pm
Yate-Loons are about the best bang for your buck IMHO, they offer a fair amount of air flow for their noise level, and best of all they are generally very cheap.
http://www.jab-tech.com/120mm-Fans-c-81.html
PostPosted: Sat Apr 05, 2008 8:06 pm
Thermaltake seems good to me. I had coolermaster before and the three fans were louder than the 6 I have now . Even the the 220 is quiet. The 120 on my big typhoon isn't even noticable compared to the graphics card.
PostPosted: Sat Apr 05, 2008 10:55 pm
It basically comes down to the ear of the beholder... I have used loads over the years and to me cheap ones and expensive ones (TT, Zalaman) can all be noisy or quiet...
PostPosted: Mon May 05, 2008 10:44 am
try this: http://www.newegg.com/Product/Product.a ... 6811999099
the fan holds to it's word as advertised (move a decent amount of air quietly) and cleaning the fan has never been easy
Image Image
