It is currently Thu Feb 21, 2019 4:22 pm
PostPosted: Tue Jul 31, 2007 2:17 pm
The system is the one in my signature down below.
Now sometimes when my system sits idle, the CPU will be around 38 degrees C. Then other times it will be around 48-49 degrees C. The ambient temperature of the room is relatively constant (although when it does get up to around 48-49 C the temp in the room probably goes up a degree or two).
Cool and quiet is disabled. So I'm not really sure why I'm getting these drastic swings. Any ideas?
Matt
ASUS M2N-SLI Deluxe MB
AMD 64 X2 4200+ Socket AM2
Corsair TWIN2X2048 2GB Kit DDR2-800
Cooler Master Centurion Black Case
SFC Silent SF-650 2.0 650W PS
Plextor PX-760A 18X DL DVD±RW
2 x Caviar WD 250GB SATA Drives
eVGA Geforce 7900GT KO 256MB
PostPosted: Mon Jul 07, 2008 10:46 pm
Only thing i can think of is if something is running in the background causing slight cpu usage.
Intel Core 2 Duo E6750 3.8ghz
8800 GTS 640MB
Crucial Ballistix 2GB DDR2 800
Gigabyte DS3R
