x-box question
x-box question
Postby ibesokewl24 » Mon Jul 10, 2006 8:05 pm
I don't really know much about x-box hardware, and am still a newb with computer hardware, but is it possible to take the harddrive, disc drive, and controller ports from your x-box and hook them up to your computer, and use it with your computer monitor? Or could I possibly hook up a USB keyboard and mouse and reformat my xbox HD and use it as a computer using Windows OS cd-rom? My x-box bores me and I wanted to try some stuff out, but not before I asked somebody that would actually know what they are doing.
ibesokewl24
Postby BIGMAN131307 » Mon Jul 10, 2006 9:00 pm
Here are a few places you can check for the needed info.
xbox scene
xboxhackz
xbox modchips
techfreaks
xbox hq
Two things you must understand before modding your XBOX.
1. Once you mod the xbox you void all warrantee.
2. One can't log onto xbox live without turning off mods (if possible).
BIGMAN131307
Postby ibesokewl24 » Tue Jul 11, 2006 7:53 pm
I've never had x-box live and I've already opened it to clean it so the warranty is already void. Thanks for the sites.
ibesokewl24
Return to System Modification
