LCD Screen (The second attempt)
Postby cavesa69 » Fri Mar 03, 2006 5:22 am
Looks geat! You took the LCD panel off of a PS1 or did it come separately?
cavesa69
Postby ~Rob » Fri Mar 03, 2006 2:17 pm
Thanks for the kind words :P
scottla wrote:I'm particularly impressed with how well such a (relatively) large screen fits into a case to scale. Most of the little screens I've seen people work with you practically have to put your nose to the case before you can see/read anything.
If your case has three floppy bays those screens fit perfectly behind, but I mounted mine where it is because of the blue square.
Rarou11 wrote: Maybe even team up with Tribal?
Wrong side of the pond unfortunately, but he's way out of my league anyway!
DAVE185 wrote:nice job rob
Why thank-you!
cavesa69 wrote: You took the LCD panel off of a PS1 or did it come separately?
It came seperately. You can get them at most indie game shops.
My kit idea was to get a piece of clear or colour plastic and bend it back a bit over 90 degrees and mount the screen with a composite/vga connection. But after my trouble with VGA it would probably just be composite. A little like this paint mock-up below...
~Rob
Postby rogue_tomato » Tue Mar 07, 2006 11:21 am
WOW! Rob that is a FANTASTIC mod, definitely pat yourself on the back for that :D And you still have a drive bay free for your optical drive ;)
Does it generate much heat? IE: did you need to install additional cooling to offset the new heat source?
"Who's doing what now?"
rogue_tomato
Postby ~Rob » Tue Mar 07, 2006 11:28 am
It gets warm but not too hot. no need for extra cooling but the 120mm blow hole will reduce my temps
~Rob
Postby sbrehm72255 » Tue Mar 07, 2006 11:31 am
I always wanted to put a LCD like that on my case when I used my Lain-Li, but never got around to it.
Good job on your install though.
I may try to cut one into my UFO case if I ever get up off of my lazy butt............... 8O
sbrehm72255
System Mods
Postby msixp_k7 » Fri May 26, 2006 8:06 pm
That @$@#$%! Looks ASOM!!!!!!!!!!!!!!!!!!!!!! Can you make me one
msixp_k7
Postby Snowfire » Fri May 26, 2006 8:57 pm
Hehe... Must be a Necromancer... ^^^^^^^
Tono Sien
Love is the greatest conspiracy, by the most loving genius.
Snowfire
Postby YouGiveMeRash!!! » Sat May 27, 2006 4:16 pm
Very Very Very nice Rob. Great job. It looks tight!
Hmm...that is an Aspire X-Infinity case correct? I have one around here.....
YouGiveMeRash!!!
Postby ~Rob » Tue May 30, 2006 1:24 am
WOAH!! Talk about bringing a thread back! It's not an Aspire (I wish it was!) It's a Jeantech Imax.
I never use the screen now! I have to plug it into the mains and then the graphics card doesn't auto-detect it, it's too much work to start her up basically!
I've moved onto the car now. Expect an update by the end of the week
~Rob
Postby tribaloverkill » Fri Jun 02, 2006 2:14 pm
Good job dude! Nice. Can't wait to finish mine:( Can I play with your's in the mean time:) Oh it's BAND SAW:)
tribaloverkill
PreviousNext
Return to System Modification
