If you wanted to insulate a mobo completely from the case floor, punching out the screw holes as the only contacts, what would you use as the material?
I have used cardboard to insulate before, but I am looking for a thinner material. Would duct tape do? Plastic?
Bottom line: What's the best, cheap, strong, non-conductive, readily available material you know of?
thanks.
