It is currently Mon Dec 10, 2018 9:33 pm
 Post subject: Any suggestions ????????
PostPosted: Sun Sep 29, 2002 1:53 pm
I think I have run out of things to mod...
KEYBOARD
Keyboard is backlit with blue EL cable
MOUSE.
Mouse has a blue backlit wheel and a small cpu fan in it(a few small holes to cool my hand) as well as a ultra bright blue led inside to view through the little 1 1/2" square window in it..
CASE
case has been custom painted (Kandi apple red, with ghost flames in white)
3 custom shaped windows in the left side...
1 diamond shaped window in the top..
AMD shaped window in the right side tinted chrome
4 80 mm panaflo fans all painted to match the case
2 radio shack 120mm 92CFM fans painted kandi apple red
Thermal take mini super orb as a chipset cooler
Volcano 7+ cpu HSF/ASIII
2 red Cold cathodes in the bottom of the case
4 red 4" cold cathodes in the top half of the case where they would fit
Whole Chassis is high pollished chrome (had that done a month or so ago at a local plating company)
custom made fanbus in the lower front RH corner of my case.
custom made baybus in the very bottom of the front of my case (only used for coldcathodes and strobe light mod)
2 custom made strobe lights mounted under the bottom of the case (red domes on them)
rounded cables
white cable wrap on all power cables
antec 400 watt PSU with a clear cover on it Clear fan w/a red LED)
replaced all led's with super brights
Network HUB
I just built a clear front bexel so I can see the insides
I need ideaz on what to do next....
I will have pics by the end of the weekend..
PostPosted: Tue Oct 01, 2002 1:06 pm
Yeah, I know what you can do since you're finished with yours.
Mod computers for OTHER people: Become a "mod" specialist in your area...turn it into a paying hobby.
John D.
________
dispensaries
PostPosted: Tue Oct 01, 2002 10:00 pm
Monitor mod? Window in the side maybe? Paint it to match your case?
Just be careful if you do open it up. Touch the wrong parts and there is enough voltage to do serious damage or even kill you. Even when unplugged!
PostPosted: Wed Oct 02, 2002 12:39 am
Try turning it on. See see if it runs :)
PostPosted: Wed Oct 02, 2002 12:40 am
ignore. mispost.
PostPosted: Wed Oct 02, 2002 5:03 pm
Are u serious Wyrm,
Theres enough voltage to kill you? holy mother.....i was thinking of doing that..not anymore......
is there anyway of grounding it so all the electricity will depart from it?
PostPosted: Wed Oct 02, 2002 6:19 pm
Yes Wyrm is correct I knew that allready...(friend of mine found out the hard way)..I haven't found one yet ..but I am wekin on it
PostPosted: Wed Oct 02, 2002 8:07 pm
Yes you can discharge the voltage, I'm just not sure about the specifics. I don't think that I would feel safe trying to explain it over a message board anyways. I would feel terrible if someone fried themselves because of my advice. (Thus the original warning/disclaimer) Opening up a power supply carries the same danger. If anyone has a reason to be inside either of these, PLEASE BE CAREFUL and be sure you know EXACTLY what you are doing.
PostPosted: Sat Oct 05, 2002 11:20 pm
I just re-read your last post here and I didn't know that I could have killed myself when I did my PSU mods....(HOLY SHEEP $HIT BATMAN)
Is it really the same danger inside the monitor or is it worse...honestly
PM and let me know what you think will work and I will let you know what I think will work with discharging the current...
I think between the 2 of us we should be able to come up with somthing that will work...
PostPosted: Mon Oct 07, 2002 2:07 pm
You can safely discharge the CRT in the monitor. The one thing that you MUST remember is that there is about 20,000 volts in the CRT. Just in case you don't know what a CRT is, a CRT is the picture tube in the monitor. If you want to know how, I can PM you if you want.
Gerald Ford (1913 - 2006)
