So i got bored...
So i got bored...
Postby Tulatin » Mon Dec 05, 2005 3:59 pm
and figured my 6800GT could use some beefy cooling to go with the nice memory sinks :twisted: . Performance tests to follow. Yes, that's a PEP66 bolted to my GPU core.
Tulatin
Postby ~Rob » Mon Dec 05, 2005 4:09 pm
OMG 8O
Aren't you worried about the weight? that could rip the core clean off!!!
~Rob
Postby Tulatin » Mon Dec 05, 2005 4:10 pm
four bolt points around the core, at about 50x50mm, plus the cooler sits on the slots next to the card, so gravity is no problem. if this is going into a vertical case, i'll make supports, lol.
Tulatin
Postby DAVE1 » Mon Dec 05, 2005 4:31 pm
8O 8O :?:
Join team 33258 today!!
DAVE1
Postby Tulatin » Mon Dec 05, 2005 5:03 pm
Gained about 15MHZ on the core, and topping out at 75 celcius under a full load.
http://img.photobucket.com/albums/v81/Tulatin/430.jpg
Tulatin
Postby DAVE1 » Mon Dec 05, 2005 5:07 pm
don't get how it works also do you have any pics of you building it ?
DAVE1
Postby Tulatin » Mon Dec 05, 2005 5:08 pm
Unfortunately no. Just drilled 4 holes after marking them, tapped them with the screws, then cleaned up and bolted the sink to the card, then shroud to sink
Tulatin
Postby DAVE1 » Mon Dec 05, 2005 5:09 pm
Tulatin wrote:Unfortunately no. Just drilled 4 holes after marking them, tapped them with the screws, then cleaned up and bolted the sink to the card, then shroud to sink
so how does it give a performance increase ?
DAVE1
Postby Tulatin » Mon Dec 05, 2005 5:10 pm
+15MHz on the core, and about a 40C reduction of temperatures, so i'd imagine it helps boost lifespan too. For the time being though, it's not practical for normal system use.
Tulatin
Postby scottla » Tue Dec 06, 2005 8:58 pm
Tulatin wrote:For the time being though, it's not practical for normal system use.
That's an understatement! :wink:
Your stats, however, suggest this beats watercooling handily.
scottla
Return to System Modification
Users browsing this forum: Lindex [Bot] and 1 guest
