It is currently Mon Sep 24, 2018 3:44 am
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
PostPosted: Sat Nov 19, 2005 1:57 pm
The LCD from frozen PC will fit in two drive-bay slots, however I'd still need to come up with a frame for it so it looked finishing. I'll have to play around with some drawings.
I'll look into the boards with composite VGA out. Running the cable back into the PC will be a bit of a cludge, so I'll have to think about how to pretty that up as well...
PostPosted: Sat Nov 19, 2005 2:13 pm
It should not be too much of a problem to solder a piece of coax directly to the video card so no wires are hanging outside the case.
PostPosted: Sat Nov 19, 2005 4:19 pm
DAVE185 wrote:
i still like the one in this thread
http://motherboards.org/forums/viewtopic.php?t=66656&postdays=0&postorder=asc&start=0
the one that comes out of the drive
I don't think he ever finished building that mod. I'm going to do something quite similar soon I think. I'm feeling creative. You can use those Son PS1 screens which are £30 over here!
PostPosted: Sat Nov 19, 2005 5:03 pm
ya i was going to buy a few of the psone lcds they had them for 15 dollars or somewhere around there at k mart
Join team 33258 today!!
PostPosted: Sat Nov 19, 2005 10:00 pm
I'm open to suggestions, but would need the step-by-step for this recommendation.
As for running the wire back in, this card has composite out:
http://www.newegg.com/Product/Product.asp?Item=N82E16814121542
In this case, can I simply snap it in and use it to drive the one monitor while my 6800GT is driving my desk monitor?
PostPosted: Sun Nov 20, 2005 5:42 am
S-video has composite built into it, but I don't know which pins they are.
SCART, S-Video and composite are interchangable btw
PostPosted: Tue Nov 22, 2005 3:04 am
Lots of LCDs here for a good price!! http://www.crystalfontz.com/
