It is currently Mon Sep 24, 2018 2:20 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Tue Aug 30, 2005 12:00 am
so felony; how did you change the colour in the end??
i really hate the way my GFX is red and in plan view from the side window. :cry:
PostPosted: Mon Sep 05, 2005 9:58 pm
Ryn wrote:
you can also try this mod on your pci cards or video card.
I did this with a test 10/100 card and held it over the UV light in my case. Works pretty well, but you need to be precise. Finding the pens was hard, and I never found the EXACT ones they had, but something close. Just need a UV light in the top of my case to complement the bottom and I'm set.
RIAA vs The People
PostPosted: Tue Sep 06, 2005 1:44 am
Do you mind to share some pics? :wink:
Join the Motherboards.org Folding Team 33258
PostPosted: Tue Sep 06, 2005 8:42 am
I will as soon as I get that second UV light in there. Otherwise I might need a better camera.
RIAA vs The People
PostPosted: Thu Nov 03, 2005 4:33 pm
No pix yet...? :wink:
PostPosted: Sun Nov 06, 2005 12:40 pm
um yea i painted the vid card but i bought a 6800gt and sold the card so yea my bad
Intel Pentium 4 2.6C HT @ 3.01,Abit AI7, Leadtek 6800GT(350/1000)@410/1150, Corsair XMS Pro Series 1GB (2x512) DDR400, Western Digital Raptor 36.7GB, Maxtor 200gb IDE, Ultra X-Connect 500 Watt PSU, Lite-On DVD-DL Burner, Big Typhoon HSF lapped
PostPosted: Sat Nov 19, 2005 2:02 pm
Anyone know how long that UV ink lasts? If it wears off, then it seems like a lot of work!
Also, on the painting part. Doesn't the heat of certain chips discolor/burn the paint? Anyone have this experience?
PostPosted: Sat Nov 19, 2005 10:53 pm
Will try and take them and post tomorrow. 8)
RIAA vs The People
