Painting PCI Cards
Painting PCI Cards
Postby felony » Thu Aug 18, 2005 12:46 pm
im painting my crappola temporary vid card and a 56k modem card. i knwo to cover the heatsink on the vid card but what else do i cover on the vid card and modem. and im pretty sure that yellow plastic enamel paint is non conductive but can some1 verify??? thanx
Intel Pentium 4 2.6C HT @ 3.01,Abit AI7, Leadtek 6800GT(350/1000)@410/1150, Corsair XMS Pro Series 1GB (2x512) DDR400, Western Digital Raptor 36.7GB, Maxtor 200gb IDE, Ultra X-Connect 500 Watt PSU, Lite-On DVD-DL Burner, Big Typhoon HSF lapped
felony
Postby kltsin » Wed Aug 24, 2005 12:05 am
Why... the beauty is there.
Parts are pretty no matter what speed or value.
If you have reactive paint and proper lighting all you need to do is trace the card edges, much more dramatic and safer.
kltsin
Postby felony » Wed Aug 24, 2005 10:07 am
well thanx for the quick reply....(sarcasim at its best) i painted the cards like 5 days ago so yea but thanx anyways.
felony
Postby kltsin » Thu Aug 25, 2005 10:56 pm
then why did you ask...
each card has a represantaion..., caps and green and gold pcb are pretty. Dont take a personality out of the system by over doing it
Just showcase the parts
kltsin
Postby felony » Fri Aug 26, 2005 5:57 am
that last comment was intended to be mean thats why i said sarcasism at its best. and it looks effin sweet wait til i upload pictures.
felony
Postby kltsin » Fri Aug 26, 2005 11:43 pm
I'm a purist at heart .... I'm sure it will look great, I just enjoy the look of electronics over too much fluff.
The end result is what counts, more so how you feel about it.
Cant wait to see it.
kltsin
Postby Ryn » Sun Aug 28, 2005 6:33 pm
you can also try this mod on your pci cards or video card.
Ryn
Postby amiencry » Sun Aug 28, 2005 6:54 pm
Ryn wrote:you can also try this mod on your pci cards or video card.
nice find sir! :)
amiencry
Postby Sabrewings » Sun Aug 28, 2005 7:27 pm
I'm doing that to my whole friggin motherboard. 8O
Sabrewings
Postby kltsin » Sun Aug 28, 2005 10:10 pm
Killer option which was exactly what I was talking about, I hand paint and use stencils for my airbrush but dont recommend it to any one as its so difficult.
This fills that gap very quickly.
Any error on pcb board is hard to erase. Using a brush I have the option of cleaning it with any diluted paint remover.. How would you fix screw ups with these pens though?
Is there an "eraser"..
Definetly a sweet find and needs no extra equipment. TY
(note I have been using tooth picks instead of brushes and works stellar but takes 3 days for one pci board)
kltsin
Return to System Modification
