It is currently Mon Jan 21, 2019 4:24 pm
 Post subject: Voltage question......
PostPosted: Tue Aug 13, 2002 9:18 pm
I am moddin my art appreciation hard drive yet again for the same FU#@$ng class wich wont end soon enough....... And I have decided to extend the window/make a second to finish the design and add a pair of red 1.7volt LED's to it (internally) the drive doesn't work as far as usability goes but it does spin so i thought it would be kewl to add some color..... I need to find out either the formula on how to figure what resistors i need or maybe someone can fid out what ones i need and exactally how to achieve this mod.....( I am hopin to make everything do it's thing from the 12 volt power that it has always used ).......(the little four prong thingy to all of you newbies)..... Thanks
PostPosted: Tue Aug 27, 2002 4:20 am
red on the
Quote:
little four proned thingy
is +5 V,
V=IR
180 ohms
