Removing "Sticker Gunk" from cases?
Postby Starbuck15 » Thu Jul 10, 2003 5:22 pm
Hey all, I'm in the process of painting my old case, and I had to remove some stickers. Unfortunatly all that sticker gunk refuses to move. I've had luck with the dremal on some other things, but I'm painting this section blue so I'm worried the dremal marks are going to show through (I tested it on some scrap metal, and in the right light you can see them. I've tried mineral oil, water, adhesive remover pads (pretty weak), can anyone think of anything? Thanks!
-Starbuck
Visit my Homepage and Ben 10 Games here
Hey I'm a GEEK and I'm proud of it!
Starbuck15
Postby Tulatin » Thu Jul 10, 2003 6:24 pm
Starbuck - head over to your local canadin tire (if they're down there) or homehardware/depot/some other major hardwars store, and look for Goo Gone - this stuff worked liek a dream for my psu.
Tulatin
Postby Starbuck15 » Thu Jul 10, 2003 7:00 pm
Tulatin wrote:Starbuck - head over to your local canadin tire (if they're down there) or homehardware/depot/some other major hardwars store, and look for Goo Gone - this stuff worked liek a dream for my psu.
No we don't have any Canadian Tires down here, however I know I can get Goo Gone. I'll have to give it a whirl, thanks Tulatin!
-Starbuck
Starbuck15
Postby NascarFool » Thu Jul 10, 2003 7:41 pm
Goof Off and WD-40 work good too. :)
NascarFool
Postby White Raven » Thu Jul 10, 2003 8:50 pm
How hard would it be to lightlly sand it off? This will also make for a great new surface ready to paint.
-White Raven
White Raven
Postby Tulatin » Thu Jul 10, 2003 11:22 pm
The Goo-Gone works the best. Trust me - it leaves NO traces, and sanding the stickers doesn't work - i've tried it. Long time no see raven -where ya been?
Tulatin
Postby Wookie8662 » Fri Jul 11, 2003 1:45 am
Goof Off, simply is the best.
Wookie8662
Postby Hardware Junkie » Fri Jul 11, 2003 3:35 am
Just get some Varsol or other Paint Thiner.
Then wash the section with soapy water and you should be able to paint over it when dry.
Postby Starbuck15 » Fri Jul 18, 2003 10:24 pm
Sorry, I forgot to reply! The only thing I had around was WD 40, and that worked like a charm! With little or no scrubbing it came off really easy, I highly reccommend it to all the cheap bastards out there. Thanks guys!
-Starbuck
Starbuck15
Postby geh1 » Sat Jul 26, 2003 11:32 pm
The only thing about wd40 is it leaves an oily residue that must be washed off, next time try some acetone (available at most hw stores and given time it will disolve almost anything, keep it away from plastic unless you arte fast) George
Asus P4P800 Deluxe
P4 2.8g at 3.1g
(2) Seagate baracudda 40g hdd's in raid
12g WD hd for bu on pri ide
512mb Kingston 3200 sdram
dvd & burner, win98se,1 of 3 in network , and 2 sec cams.
geh1
Return to System Modification
